Lighting environment too dark.
justcruisin
USA
Hello, received this message during last flight using Litchi.
I was flying during daylight over water without much sun reflection, so I suspect that may be the issue. Anyone have experience with this?
Thanks!
Reactions: Droniac
You might try flying with DJI Go during these occurrences to see what message it gives you, but both controller apps will be responding the the same codes from the aircraft, indicating that it is not detecting enough light to depend on the VP systems.
Personally, I've never had this happen in daylight (even over water), only at dusk or full night. You could try cleaning the sensors.
Chris
Reactions: Droniac
Q14
