Litchi and M2Pro precision landing........
Prmath
NW FLa
Since DJI didn’t build precision landing into the Go4 app......
is there any chance it will work with Litchi. I understand that all the hardware is in place on the M2P but the DJI software is the issue.
TIA, Guys
I was using Litchi today and it’s RTH was almost perfect. Much better than DJI.
i have notice the Litchi RTH is much more accurate than DJI Go4.
Litchi RTH is not more accurate than DJI RTH.
Litchi RTH is DJI RTH.
Litchi does not have any special RTH function.
It just uses the RTH function that DJI baked into their drone.
RTH uses GPS and GPS is not pinpoint accurate, it will usually place you within +/- 2 metres but sometimes more than that.
Try 10 RTH landings and you'll find the drone doesn't always land in the same position unless you enable the Precision Landing feature which uses optical technology.
And the Mavic 2 does not have the Precision Landing feature.
Can you Help i takeoff and fly 200 meters and then rotate the drone to look back at my position and the drone starts to return to me and hovers above me. I am using the litchi app 2018. And it also done the same thing with DJI Go 4.
How can i stop it from doing that. I'm new to the app.
To start, reset to default all of the factory settings on the aircraft.
The recorded flight data would probably explain what's going on.
Go to DJI Flight Log Viewer - Phantom Help
Follow the instructions there to upload your flight record from your phone or tablet.
Come back and post a link to the report it gives you.
Rythorne
