Litchi and No Fly Zone
bcoles
I recently loaded a Litchi mission to fly around our home which is in a DJI Blue NFZ. Today I got the unlock code, loaded it and successfully flew a short take off and landing on the DJI App. Then turning everything off. I next swiped the DJI app off the iPad and turned on the controller, aircraft and the Litchi App. Everything showed up as per usual so I tried to take off-no luck. I then looked at the controller and NFZ was scrolling on the screen. Is there a way to fly a Litchi mission in Blue NFZ ? I did not have the DJI App on/running during my attempt. Thanks. Bryan.
Interesting. Can you share the coordinates where you were attempting to fly? Which model drone do you fly? I had a situation where I discovered that I would be in Class D airspace, went on my computer to get DJI unlock codes. I had no issue flying with Litchi, within 2 miles of a regional airport once I got it unlocked (and got ATC authorization). I was flying a M2 Pro
You should try unlocking with DJI app do not turn off the drone exit the DJI app and then try the other app.
Reactions: 254drone
Turn on the GO app, unlock the drone, close GO (leave the drone running), start Litchi and run your mission.
Reactions: 254drone
The flight restriction info is stored in the drone. Once the drone is power reset. The restriction settings will fall back to the default.
I think Vic might be right. It's odd, but when I've accidentally opened the Go4 app, turned on the drone and realized I needed Litchi, many of the settings in Go4 got transferred into my Litchi flight. The one that comes to mind was when I had set the camera setting for the first time to film in D-Log. I hadn't done that in Litchi, but that's how it got recorded.
It's that the unlock lives on the drone. Litchi can not send it over, only GO4 can.
Thank you everyone. I will try exiting Go4, run Litchi but leave the drone running. Will try tomorrow and report back.
I realized I did not report back later. I turned on GO 4, unlocked the area, kept the drone running, swiped GO 4 off my iPad, launched Litchi, and ran my mission successfully. Thanks everyone. Bryan.
This does not work when using my Mini 2 with R/C controller and pixel 4 phone.
Litchi still won't let me take off because of no fly zone.
I have been using Litchi in NFZ since it was available. Make sure to do the following steps:
  • Power on drone
  • Power on RC
  • Open DJI FlyApp
  • Unlock the NFZ
  • Force / kill DJI FlyApp
  • Open Litchi
  • Load your Waypoint mission
  • Execute the mission
camposbrito
