Litchi C1/C2 key and 5D button questions/help
marklyn
Austin, Tx.
Long time Litchi user here. All up to date on current apps (DJI Go 4/Litchi), firmware and iOS updates.
I have a Mavic 2 Pro and use an iPad mini 5. I seem to be having some trouble programming the C1/C2 keys and some of the 5D button assignments.
For example, in Litchi settings:
I want my C1 (left key) single press, to do Center Auto focus but instead it starts/stop recording.
I've set my C2 key (right key) single press, to focus to infinity and when I press it it appears to do so but under focus settings it still says "auto".
I've set my 5D button center to change exposure setting but it does not bring up the exposure settings when pressed.
Also set my 5D button up/down for Digital zoom in/out respectively, but that doesn't seem to happen either.
I've restarted the Mavic, controller, apps, and settings are still there when all is back on but those buttons don't seem to work as assigned.
Would appreciate some insight or if someone else could try this with same combination of hardware.
GLobus55
