Litchi display a slow SD card popup?
QldKing
Hi all
Just started to fly waypoint missions with the litchi app connected to the mavic air. I *think* I am seeing a popup message on first connection that the SD card is slow and either needs to be formatted or changed to a faster one. Am I reading that message correct? I thought I had a fast card - what should I be looking for ? Or will formatting it from litchi resolve the message?
Hi all
What card are you using?
Reactions: QldKing and Kilrah
The documentation for the Mavic Air specifies an SD card with a "Class 10" or "UHA-1" speed rating.
This means that your card must be able to write data at 10MB/s or faster.
Your card appears to have the "U 1" (and older "C 10") rating. This means that your card can write at 10MB/s.
So, your card rating is ok. If I were you, I would try formatting the card as Litchi suggests and see if you still get that warning.
Reactions: QldKing
Thank you. So format the card from the DJI app. Thanks for your help.
Jacob D
