Litchi hover and soft focus
AlR
Hi Everyone,
I purchased Litchi and so far I'm very pleased with the results.
I have a couple of questions that someone may have the answers too?
I) in waypoint mode - is there anyway to set the Mavic to hover for a period of time?
Ii) when I tap on the auto focus box - it is slightly soft focused - is there a way to manually focus or fix the issue?
Many thanks in advance for your assistance!
AlR
YES this can be done using Waypoint Actions. One big caveat though with Litchi you must disable Curved Turns to use WPT actions. So your mission would have to use straight lines between WPTs. Having set the Path Mode to "Straight Line" in Mission Settings, you will see each WPT now has an actions pulldown menu available where you can program numerous things such as a "Stay For x seconds".
I have had this on one occasion with Litchi and fixed it by resetting the camera. Quickest way to do this without losing your settings is to go in to Camera settingsand toggle your camera from NTSC to PAL and back or viceversa. This should fix things allowing sharp focus again.
Dear Logger,
Thank you very much for your response. I'm giving the waypoint changes a go now :)
I'll also give the video format change a try too.
Many thanks!
AlR
Rolling Horizons
