Litchi Hub to DJI RC2 Mini 5 Pro Waypoint Issue
tinpusher
I'm using Litchi Hub to create a waypoint route then export it as KMZ. The KMZ is uploaded to DJI RC2 and I see top photo when I first look at newly added route. Unfortunately within minutes it turns into bottom photo on its own. Any ideas would be much appreciated. Thanks
This is normal. It occurs when a straight-line mission is loaded into DJI Fly. DJI Fly can only create a curved turn mission. A straight-line mission can be externally created, loaded, and executed with DJI Fly. It just looks wonky as you have found. It will execute properly.
Thanks. I was wondering if that was the case as I saw duration and distance did not change. I'll try it out tomorrow.
MorePi
