Long Battery Charging Time
Marty Markoe
Yorktown Heights, NY USA
Site
www.martymarkoephotography.com
Received new Mini5 Pro Fly More Combo Plus with 3 Extended batteries. Started charging 12 hours ago. Only the battery nearest the USB cable is fully charged with 4 solid green lights. The middle battery shows 2 lights, one of which is flashing. The 3rd battery shows 3 solid lights with USB cable disconnected.
Is this long charging time normal???
Marty Markoe
Part 107 - 10 years flying experience
I don’t know about the plus batteries, but I’d be wondering what is going on if it were the standard batteries.
Are you sure the power supply you are using is powerful enough? Can the USB cable carry that power? I ended up with a 100w from Anker, with 2 outputs. Use one output to the charging hub with 2 batteries in it, the other to the drone with the 3rd battery in it. Get all 3 charged inside an hour.
Reactions: Cafguy
dhakospd
