After nearly 150 flights with my Mavic 2 Pro and 400+ in total with my previous drones (P3P & P4P+), I "finally" joined the club of those who lost a drone ...
Nothing fancy and daring, just a classical flight that started well but then started getting a warning at the 56 seconds, with the battery level going from 91% to 0% and "informing" me that the controls of the drone would be from now limited and that immediate landing procedure had started ...
1m34 it was in the water ...
Between the first message (that was beeping up every second until the end), I could only control the rotation of the drone, but in no way go forward, left or right and of course not backwards ...
So, it didn't fall or drop from the sky, but was a "controlled" descent but with very limited possible maneuvers which really frustrated me since from 90 meters to ground or water level, I technically had the time to go from the middle of the canal and land on one of the banks of the canal I was flying above.
All my batteries have been serviced every 20 flights and no pre-warning signs or messages prior to this incident - The battery itself had only 43 charge cycles ...
Here is the airdata link in order to try to understand what happened ...
Clearly possible to see that it is the battery that failed but at the same time, I don't get how such a product can fail when I never had an issue with my P3P and P4P+ (still have the last one that works perfectly)
Also, planning to send some feedback to DJI - Not that I expect anything from then, out of warranty and no DJI fresh, but they should be informed that such an incident occurred with a person who has always taken good care of his equipment ...
Thanks in advance for anyone who will give some feedback on the info provided in the airdata link ...
Matt
Matt
