Lykus Titan MM200 Hard Case for Mini 2
PJordan
Scotland
Loving my new hard case for the Mini 2, It is just perfect and extremely well made, very compact in size. It only took 2 days to arrive through Amazon here in the UK.
Lykus Titan MM20020210118_114525757_iOS.jpg20210118_114602161_iOS.jpg20210118_114649828_iOS.jpg
Reactions: raymairjr
Glad you posted this. I just ordered this case from Amazon. My primary reason for buying this case as the video show being able to also put an iPad mini in there. And that’s what I use with my Mini 2. Thanks for the pictures. Mine should be here tomorrow.
Reactions: PJordan
also got one of these the only gripe i have is that they could/should have included an option for a strap to carry over shoulder
You could use the two padlock holes to attatch a strap if needed, using just the two lower holes so that the lid still opens. Something like the Peak Design quick release straps would be ideal for this situation.
Any idea how the gas pressure dial works? The one page sheet that came with the case didn't explain how to use it. The dial looks a bit flimsy. Other than that, a great case. Even has a recess at the bottom of controller foam to fit an ND filters case.
Was wondering exactly the same! Not sure but it seems to be a manual pressure dial so I am just keeping mine slightly open for the time being unless someone suggests otherwise.
I believe that is just a pressure relief valve so that the cover closes easier. If you didn’t have that the waterproofing would make it very hard to close the lid. I believe that is it’s only purpose. No adjustment and only allows air to come out and nothing to go in....that’s just my understanding.
Reactions: PJordan
dronephotog
