M2P, H265 & Final Cut Pro
Skeye Ireland
Hi all, i hope i'm in the right place. I haven't found a solution to this issue, can you help?
Issue:
I record in 4K H.265 on the Mavic 2 Pro. When i copy the video file to my MacBook Pro, it plays perfect and looks perfect. When i import this into Final Cut Pro (10.4), it looks very over exposed. I can use the settings to bring this back to a usable look but i don't have the time to be doing this with every imported clip. As i said, if i play the file on it's own, there is no issue and it looks perfectly fine, it's only on importing, the issue is there. If i import any other videos into Final Cut Pro from e.g. a GoPro or DSLR, i don't have this issue at all so that leads me to believe it's something to do with the H265. I could try using the H.264 format but this doesn't address the issue.
Anyone experienced this and provide a solution?
CMDR DV TEARDROP
