M2Z Gimbal slightly off centre
Ben1UK
UK
I have run the auto calibration multiple times on a perfectly level surface and done the same with the IMU but still the gimbal points slightly off to the left every time. I can manually correct it with the adjustment on in the settings but is there any way to make that permanent? So it remembers that position next time I calibrate it?
You have little time left. Send it back to DJI.
I don’t really want the hassle of sending it back I just wondered if there was a quick fix. It’s perfect once manually adjusted
When you’re warranty expires, you will be on your own.
You might be able to program one of the buttons to move it up and down and it should recenter it quickly .
Phantomrain.org
Gear to fly your Mavic 2 in the Rain and Float on water
winona98
