MA2 Compass Calibrating Location
TheFlyingGuy1
United States
Sorry if something like this has been asked. I didn’t see anything in search.
Hello!
I will need to calibrate the compass on the new MA2 but I have a few questions about the location to calibrate it.
The best place I have near me is about 20 feet directly under a power line with dirt and bushes all around. I don’t have a grass open area or anything. It is the very end of a small power line and there’s a large cell tower about 200ft away. Will I be ok to calibrate there or do I need to find an open park?
Thank You!
I hope this is the correct category. I apologize if it is not
Ok. There’s also a school behind me with a huge grass field. Maybe I can go there. I wonder if the cell tower about 150-200 ft away will be an issue
Transmissions from a cell tower won't have any effect on your compass at any distance.
The cell tower itself might have an effect ... but only if you are within a couple of feet of it.
Reactions: Thomas B
Ok cool. I just want to make sure it’s done right since the MA2 does not have a backup compass and IMU. I also want to confirm the IMU is fine to calibrate on a table indoors right?
That should be fine. Just be sure to avoid metal objects, conctrete, and that location should be good.
Reactions: TheFlyingGuy1
Your IMU probably doesn't need recalibration anyway but if you were to recalibrate it, all you need is a perfectly level surface.
the IMU is not affected by electromagnetic fields.
Got it thank you!
Thank you to everyone who replied. I got an extremely fast and great answer!
Yes, I use my dining room table for the imu, make sure its level if you can
chucklitchi
