Many errors
WNYDroner
Jamestown, NY
Hello, I flew my Mavic air 2 about a month ago ands had no issues. Today I went to fly and had a lot errors. (See screenshot) When trying calibrate the I’m or the compass nothing happens. Does anyone have any suggestions? I don’t have DJI care anymore so I do t really want to send to DJI as I think the repair may out way the value of the drone.
Thanks in advance!View attachment 176324
There are serious issues with the drone, it looks like a bunch of components are broken or disconnected.
Calibrating the compass isn't going to solve those issues.
If you restart it and the same error conditions are present. like the first item says: Repairs required.
Thats quite a list where did you start this drone?
Kinda looks like some of those errors could be cleared by Getting away from metal and such. But Your Drone has some problems and you have two options:
1. Send it to DJI and have the Drone repaired OR
2. Try and fix the drone yourself.
If you are new to that - Don't try number 2 -You will end up buying junk you don't need.- Happens to us all.
My Opinion-- 2 Send it to DJI. It will NOT cost you a bundle and you will get a refurbished drone for a pretty cheap price!
Reactions: Nanny Ogg
The compass message probably has nothing to do with magnetic interference.
It's more likely that the compass module (and everything else) is disconnected.
That would give the same (poorly worded) message about the compass.
Reactions: Cafguy
If you are not used to working on this type of small device definately send to DJI. I doubt that the bill will exceed 200.00. DJI repair is always a good choice. They just replace the failed subsyetm and send you a rebuild. (reycle yours to someone else) On there larger drones like Inspire or Matrice it has been my expierence they repair unless totalled.(unless it was under warrenty)
destinyrett
