No, I don't think so. It should be 4000x3000 pixels.Could be let me check back with the pilot. I take it the resolution is not selectable then?
OP has a Mavic 2 Enterprise (M2E), it has only the 12 Mpix zoom camera, like the Mavic 2 Zoom.both the zoom and the 'Hasselblad' camera should capture at 4000x3000px for both JPG and DNG (RAW)
I think this was a rather complicated explanation.Waynorth is right - both the zoom and the 'Hasselblad' camera should capture at 4000x3000px for both JPG and DNG (RAW). The DPI is a printer setting that you can raise or lower using the editing software just before output to either JPG or TIFF. If you're outputting drone image files (either JPG or RAW) after running them through an editor: the low resolution and reduced size is down to you having the wrong output parameters for your requirements.
Uninstall your editing software and get rid of all the user settings files as well - then re-install your chosen photo editor. This should reset your output parameters without you having to fanny around trawling through the preferences settings menus. In the output tab: choose 8-bit JPG high quality (as close to 100% as you can get it) - in this menu tab: you can also set the output image DPI (Dots Per Inch) in case you want to print the image.
There's no need to do anything as your camera is shooting full resolution images already.We have a Dji Mavic 2 Enterprise drone. We need some advice on how to set the resolution to a higher level, currently we are only achieving 960x720 pixels at 96 dpi, and cant find how to change this in the settings, any help appreciated.
