Mavic 2 Controller and MavMount
ddodell
Phoenix AZ
Just got a MavMount for my controller, and unless I'm missing something, I'm having a really tight fit of the USB cable under the mount.
I thought possibly the USB-C port on the bottom of the controller would also work, but it appears only to be for charging?
Better cable suggestion for USB-C to Lightening that fits in this situation?
Thanks
David
I use a right angle cord from there, that one looks a little thick. you could shave a little of the extra plastic off potentially if you'd like to use that with no bend, or grab a right angle from amazon.
its really tight in that area.
Yep, did you find a brand on Amazon with the right angle that worked well for you?
A couple years ago. Probably not there anymore. But if you have a file, that could be golden in a minute.
M5P
