- Joined
- Sep 9, 2018
- Messages
- 312
- Reactions
- 161
- Age
- 52
just saw this online & on FaceBook... what ya'll think.... https://www.buy2taobao.com/en/item/575737497486.html#.XIW55LfmjN4
Any links to anyone on FB or elsewhere online that has tried it?just saw this online & on FaceBook... what ya'll think.... https://www.buy2taobao.com/en/item/575737497486.html#.XIW55LfmjN4
If someone like MaxxUAV would make and sell one with quality control for the M2, it would be a big seller, as you can never have enough flight time, especially with a 5+ mile stock range!If interested, choose "Royal 2 Dual Battery 7900...".
The battery case looks handmade although said to be 3D printed, but the edges definitely not polished.
The QA basically doesn't exist as a few customers said it works whilst some reported fire or swollen, and the customer service is almost zero. So quite risky.
When it works, 42mins flight time, max distance is 15 km (one way).
Since no aircraft mod is necessary to use it, flying with it shouldn't void any aircraft warranty, as its prior use should be undetectable afterwards. Crashing with it installed would likely void Refresh, but not when flying otherwise with a stock battery. It's a perfect solution for occasional longer flights, where serial battery swapping won't get the job done. Use this battery instead. Eagerly looking forward to reports here, about how it works out, for our volunteer beta testers!A member around here is doing a build, and stated he ordered one! This is exciting, because if it does work, then win. Again, after warranty is gone. Also talk about the smart chip being in it, or not... lots of questions, keep an eye out... some should be answered soon.
Agreed. Safest to test with a new bare M2 aircraft from MidCityHobby on eBay for $475.Ehhh... the battery in this is eccentric to the design, specs and more. 1. On the log files, they can tell it’s not a DJI battery. 2. Being the battery is such, its not like adding landing gear, LED lights, or other items... that don’t tamper with the electrical system. All I’m saying is that any modification won’t alone kill the warranty... but any problems, the first place they will go is right to the unapproved parts.
everyone that owns a Harley thought they could tune there bike, and no one will know... I won’t void my warranty... Sad to say... Many are now without, and they bought a very well known product.. Like Vance and Hines, Dyno jet... Anythjng thing that’s NOT a Harley brand part...Voids your warranty. If they can do it, DJI can.
Totally off topic, but if you buy it, you should know what your doing. Personally I’m looking to buy a second Mavic 2 for testing purposes...
For the Harley example, I think voiding a warranty using a non-oem part that is at same specs and not the cause of an issue is a violation of the magnuson-moss act.Ehhh... the battery in this is eccentric to the design, specs and more. 1. On the log files, they can tell it’s not a DJI battery. 2. Being the battery is such, its not like adding landing gear, LED lights, or other items... that don’t tamper with the electrical system. All I’m saying is that any modification won’t alone kill the warranty... but any problems, the first place they will go is right to the unapproved parts.
Dan, we are NOT talking about an exact OEM replacement. I’m the director of service for Harley... any Non-oem part to upgrade of modify the current bike, can and will void the warranty. The example above is like adding a car battery to a bike! Can it work, sure! Does Harley have to warranty your bike after install, hell NO! It’s not an approved OEM part. I’ve been doing this for 25 years, I’m old... you can’t screw with warranty like you used to be able to! Computers and sensors will trip, it WILL be recorded, and then at its first available time, it will report to the main company. With DJI, that will be when you crash for some reason, maybe not even ties into the battery, but..... will still void!For the Harley example, I think voiding a warranty using a non-oem part that is at same specs and not the cause of an issue is a violation of the magnuson-moss act.
However an issue that can be potentially tied to a modification, rather than just a replacement part, could void the warranty.
This is perfect, but it needs a camera for FPV.... I would pick a zoom if someone wanted a inexpensive test unit. Personally I’m looking for a pro, due to having a zoom. This is a great choice.Agreed. Safest to test with a new bare M2 aircraft from MidCityHobby on eBay for $475.
Brand New DJI Mavic 2 PRO Drone Only new replacement for crashed drone | eBay
Find many great new & used options and get the best deals for Brand New DJI Mavic 2 PRO Drone Only new replacement for crashed drone at the best online prices at eBay! Free shipping for many products!www.ebay.com
That still could be a violation of the Magnuson-Moss act, depending on the defect. If you upscale the battery and the water pump falls, Harley would have a hard time proving the battery or even battery installation caused the water pump failure.Dan, we are NOT talking about an exact OEM replacement. I’m the director of service for Harley... any Non-oem part to upgrade of modify the current bike, can and will void the warranty. The example above is like adding a car battery to a bike! Can it work, sure! Does Harley have to warranty your bike after install, hell NO! It’s not an approved OEM part. I’ve been doing this for 25 years, I’m old... you can’t screw with warranty like you used to be able to! Computers and sensors will trip, it WILL be recorded, and then at its first available time, it will report to the main company. With DJI, that will be when you crash for some reason, maybe not even ties into the battery, but..... will still void!
This is real world example... customers adding a tuner to a bike, Non-Harley, then it oil sumps, and destroys the crank sensor. Due to the aftermarket tune noted when checking engine codes reported, you’ve now destroyed your factory warranty.
Buy a unit for testing purposes.
We are WAY off topic! If anyone would like to talk about this more, please PM me, and we can talk. For now, think this has been diverted enough.
Sorry Captain B!
