Mavic 3 E FlySafe database update. Where is it?
astroprojector
Hi There
I am trying to update the FlySafe database on the Mavic 3 E, but I cannot find the option. I checked in the Fly App under About and I do not see the options to do that. I also checked setting in the user profile and there it is also not there. I am using Fly App version 10.1.8.18.
Can someone please pint me to the right direction?
Thank you
Key points about FlySafe and DJI Enterprise drones:
  • Functionality:
    The FlySafe database helps prevent flights in sensitive areas like airports, power plants, and government buildings by displaying warnings or preventing take-off within restricted zones.
  • Accessing the database:
    To access FlySafe features, operators of DJI Enterprise drones use the DJI Pilot 2 app, which needs to be connected to the internet to download the latest database updates.
  • Offline capability:
    While most operations require an internet connection to access the full FlySafe database, some DJI Enterprise drones can be configured to operate in a "local data mode" with pre-downloaded restricted zone information for situations where internet access is limited.
Hi There
Thank you
Usually it will give a pop up when it needs updating,
If you tap profile> settings its on the right side under check for firmware updates
The enterprise edition aircraft update the FlySafe database via the DJI Pilot 2 app not in the Fly app. This is according to the DJI website where the info I posted previously was copied from.
Reactions: Exphantomflyer
Spot on @DoomMeister. From the main landing screen, open the map, and FlySafe Database is right there. Touch on it, and choose update.
CMDR DV TEARDROP
