Mavic 3 Pro Cine Screen Rotating
High Country
Iowa
I recently purchased a New Mavic 3 Pro Cine from Best Buy. At first start up everything worked fine but after updating firmware the screen rotates CCW 90 degrees after selecting “Before You Fly” and the only way to get it to flip back is to go back to Home Screen and select settings. I tried everything with DJI with no success; then I returned to Best Buy for an another new DJI Mavic 3 Pro Cine. Once again the same issue occurred. Went through same exercise and returned to Best Buy. Now on the third one and the same problem exists. Anyone else seeing this issue?
Your issue is clearly related to the RC Pro FW and its settings, and not the drone. Exchanging the drone won't change anything, nor will exchanging the RC Pro hardware, since this is now a reproducible FW and settings issue on three different new RC Pro hardware units.
Have you contacted DJI Support regarding the issue, and had them escalate your issue to the "relevant team" for further evaluation?
I have two RC Pro units myself and have never experienced the issue, but I have also not updated the RC Pro FW on either in quite a while. No need. The Mavic 3 Cine is a very old drone, despite being new. It's FW should be fully mature by now
What FW version do you have installed on it, when was that version released, and what version did it come with out of the box?
At the very least, by the third unit, I would NOT have updated the RC Pro FW, and would have flown it without updating. Then, you would have even more proof of a FW bug in the most recent FW version that you keep updating to. What is in the most recent FW that is so important anyway?
I'm also not clear on how serious of a problem this actually is, while you get it sorted out with DJI. If it always boots up in portrait mode and you can immediately change it back to landscape mode in Settings, and it stays in landscape mode until you reboot, that sounds to me like a very minor inconvenience, and certainly not a big deal worth replacing three units over to no avail.
I have contacted DJI with no success. They want me to send them the entire Fly more combo to them and they will send me a new one, but that would void my Best Buy total membership 2 year warranty. If I do not push the new updates, then I cannot access the device manager to bind the drone to the controller. I will get the version later today and respond. Thanks for your input.
I took a quick look at the manual for the controller, and you are correct, it doesn't look like they included the rotation lock button in settings. However, there is no doubt your screen rotated, so DJI didn't remove the rotation functionality, just the button.
If it were me, I would try side loading a rotation app off the play store and see if it makes a difference. I know that loading apps on the RC is not a straightforward process but it's doable. Certainly less of a hassle than sending the kit back to DJI.
Ok, I have tried downgrading the RC Pro firmware from the "DJI assistant 2" to previous versions with no success fixing the issues and I also tried downloading rotation apps with no success either. Has anyone else had these issues? It appears that the actual app causing this is the DJI Fly app. The controller does not allow me to downgrade or load an older version of this. The version that the controller defaults to is version 1.13.9 and if I do not update from this version, then the screens do not rotate and work great; however if I do not update then the DJI Fly app does not have any "Device Management" option under "Profile" within the home page of the app and therefore I cannot see any devices and be sure that the controller is bound to the drone. Once I update the controller with the most recent DJI Fly version 1.16.4, I get the "Device Management" screen and then can be sure that the controller is bound to the drone but then the screen rotation problems starts. DJI tells me that I must be sure that the Drone and Controller are both visible in the Device Management screen. Any further Advice?
destinyrett
