Mavic 3E-ND Filters ?
Pitchpost
SD
Hello,
Just purchased a M3E, and would like a set of ND filters, not seeing any specifically for the 3E, does anybody know
if there is a set that will fit, perhaps from a different Mavic?
Thanks for any advise.
Hello,
There is not a set of ND filters specifically for the M3E that i know of. I fly the M3E and i got my ND filters from a fellow member on here who didn't need his anymore. You need to look for ND filters that are made for the Mavic 3. Not the classic, not the pro, not the cine, not the enterprise. The original Mavic 3, which i believe is discontinued now, but you should be able to find these filters.
The original mavic 3 essentially has the same sensor (camera) layout as the M3E. This means the ND filters for the M3 will fit the M3E. The set i have is the 8, 16, 32, 64 made by DJI, but there are other brands out there as well and also higher values that block out more light as well (i.e. 128/256).
If you have any more questions, I'd be happy to help. Just google ND filters for the M3 and make sure (visually inspect) the filter shape/layout matches the sensor configuration on your drone. As long as the config. matches you should be fine. I hope this makes sense. Check it out and you should see what i mean. Good luck.
Reactions: TonyPHX
jsnhunt
