Picked up the creator combo a few days ago, and I have to be doing something wrong. The RC Pro 2 fits in the front left section of the 2-section divider but it is a bear to get out. Am I missing something?
New the RC Pro 2 is packed in the rear left pocket above the cardboard box with charger brick. The battery charger is in the front left pocket on top of the box with cables and spare blades. The bag is the worst part of the M4P.
I recommend installing a neck strap onto the RC Pro 2, using the two screw holes on the front. When you insert the RC Pro 2 with the screen facing the interior divider in the front left section, antennas down, you can then easily pull it out by the neck strap, and the screen is well protected, with the neck strap set loosely on top. The battery hub with batteries then fits behind the RC Pro 2 in the left rear compartment. If you put the spare props in the front pocket, it will create enough tension on the closing buckle to stretch it securely into place, so it won't pop open from insufficient tension. Works for me.
