Mavic 4 Pro Exposure bracketing question, (aperture no staying fixed)
Paul2660
Brief history of my drone use, I have owned the P4, Mavic 1, Mavic 2 Pro and now the Mavic 4 Pro. I am mainly a still photographer, and I utilize the exposure bracketing feature on all my drones. I have the Mavic 4 Pro with the RC Pro2
I have attempted this with the Mavic 4 Pro, and have run into an issue where the aperture is being changed on 3 or 5 shot bracketing. I am using the pro mode, and have all the auto selections not in yellow. I can pick the pick the aperture either by using the control wheel, or the original way by entering into the details for M mode. No matter what I select, the Mavic 4 Pro will not shoot 5 per 3 brackets with a consistent aperture. I changes the shutter speed, (which it should ) but is also changing the aperture. Example, one image is taken at F 4.0, then 2.2 then 2.0. This is unique to any other DJI drone I have used.
I am hoping I still have a setting off, but have gone through the menu and can't find anything else to change. The fixed aperture is important mainly for DOF. This issue is only a problem of course on the main lens as the other two are fixed F 2.8.
Can anyone check with their Mavic 4 Pro and see if they get this same issue ( exposure bracketing in M mode)
Also I need to open a support ticket with DJI, but since I don't believe they have support for the Mavic 4 Pro in the U.S. (please correct me if I am incorrect), the only place I can think of is the DJI forum.
I am running the most current firmware on both drone and controller and have most current version of the fly app. The version I have of the fly app seems to be correct as it shows all three lenses and has the switch setting to turn the gimbal to vertical.
If I manually exposure 5 brackets (made much easier by the new control wheel) the aperture stays fixed, but in the furture I would rather not have to do that.
Thanks
Paul C
Fixed it, due to my misunderstanding. It works as it should once you have the setting correct.
Reactions: GadgetGuy
fototaker Tony
