Mavic 4 Pro range observations
NYanakiev
London, UK
Hi folks. Having some issues with signal quality lately. I went to the Peak District over the weekend, as well as to Lincoln, Nottinghamshire. Started getting signal warnings after about 300 metres.
After a DJI Assistant II refresh (drone+RC Pro 2) things look a bit better but still nowhere near the advertised range. Got to about 500m before signal started degrading.
Thoughts?
Thoughts?
Signal range is a complex issue and you can't expect to achieve the Max Transmission Distance any time you fly.
Actual range is going to vary considerably with local interference levels and the amount of trees or other obstacles between you and the drone.
Just read the full details in the specs to see that it's not as simple as a single number for distance.
Max Transmission Distance (unobstructed, free of interference)
FCC: 30 km
CE: 15 km
Measured in an open, outdoor environment without interference or obstructions and represents the farthest communication range under each standard.
Max Transmission Distance (unobstructed, with interference)
Strong Interference (urban landscape): Approx. 1.5-6 km
Medium Interference (suburban landscape): Approx. 6-15 km
Low Interference (suburb/seaside): Approx. 15-30 km
Measured under FCC standard (distance in CE will be less) in unobstructed environments with typical interference. Used for reference purposes only and provides no guarantee for actual transmission distance.
Reactions: NYanakiev
FCC: 30 km
CE: 15 km
Yes, that does make a lot of sense. Thanks for sharing!
ASZ20
