Guys i made this earlier this evening and its dead simple and works brilliantly
You cant beat cheap mods ?a great use of some scrap alloy bar, well done
Unlikely i hope the 2 extending bars are not connected to the antennas or il be weakening the signal sorting them out ?Nicely doneI wonder if it helps with the antenna signal to.
Wonder how durable the plastic tabs are hmmFrom a old modder I found wider works better at the top as far as holding the pad from swinging .
Something like these
Free Tablet Mount Giveaway!
Printed this file off thingiverse but unfortunately my iPad Mini 2's performance suffers when running the DJI Fly app. I get the CPU error after only a few seconds. Anyways, I thought one of you fine enthusiasts might be able to use it. It's free of course, you just have to pay the shipping. It...mavicpilots.com
If your talking about at the top that goes over the tapletWonder how durable the plastic tabs are hmm
Time will tellNo i meant the little tabs that catch behind the bars on the controller
haha not quite, by extending the actual antenna which is inside the plastic holder as it touches against this, in between the ipad . I wondered if it would increase the signal slightly, thats all.Unlikely i hope the 2 extending bars are not connected to the antennas or il be weakening the signal sorting them out ?
Nope no improvement and if anything even without the bracket the range seems to be quite a bit worse than my old m2phaha not quite, by extending the actual antenna which is inside the plastic holder as it touches against this, in between the ipad . I wondered if it would increase the signal slightly, thats all.
