Mavic Air 2 RMC Virates ?
AusTrekie
Yarra Valley Victoria 🇦🇺Australia
2 minutes ago
Has any one experienced Haptic Viration with The Mavic 2 RMC, after several vibrations, which I thought was caused by my iPhone DJI Fly app through what appeared false obstical detection, no visual obdticals, according to a reply from DJI the RMC will vibrate if in certain conditions, and front obstical detected ! Has anyone else experienced this with the RMC ?
2 minutes ago
Not sure what your saying, are you asking if the Remote gives warning vibrations as well as tone ? If so yes it does. :)
Reactions: Thomas B
Thanks for the reply. Does the Remote vibrate on obstical warning ? I was initially informed that the RMC does not have vibration ability ? Only the iPhone can vibrate, which may give the impression the RMC vibrares. Is this true ?
I might have miss spoke, I thought this was a Mavic 2 question....Seems your actual device running the app is doing the vibrations on a MA2, I know it will vibrate in wind warnings and aircraft (Vicinity) alerts..other than that can't help. Can tell you in a M2 that the remote doesn't vibrate in O/A though;)
Uh, M2 (Mavic 2) remote does vibrate with OA.
I would have thought the MA2 RC would also vibrate on OA though I get it if it uses the mobile device vibrator. Anyone know if the MA1 did?
Easy way to tell is approach an obstacle with app not running.
I believe the vibration comes from the device, not the remote. I may try it out later just to be sure...
If that is in response to my post, I fly a SC and I don't get vibration on O/A (They may have missed that function on the App crossover)...well not that I noticed (I will go check and report)...just that obscene beeping. I linked O/A to C2 to toggle on and off and stop that beeping when not needed, when I am up and about I turn it back on for emergency RTH.
Now that I think about it, the controller will beep. I get that annoying beeping sometimes on takeoff. My phone's audio is mostly set to silent and it still beeps so it must be the controller.
I'm not sure that's the case. I had my phone accidently on silent and all I got on O/A was the vibration.. Not sure if it was the RC or phone vibrating though.
The beeping I think wasn't obstacle avoidance, there was a period of time (a couple of firmware updates ago) that it would just beep for the first couple minutes of the flight until it got up in the air. Everything else was working so I'm not sure what it was beeping about. It has not done it lately though...
I've never felt a vibration with either. I don't have my phone set to vibrate.
Obstacles close to you during takeoff? Perhaps you yourself being detected as obstacle?
Thanks for your comments, I was not close to the drone during this issue, the problem appeared to be caused with drone detecting obstacles, but no visual obstacles apparent, a vibration occured, was not sure if RMC or iPhone created the vibration,drone appeared to pause when this occured briefly, happened several times in good wether conditions, did a refresh of recent updated firmware, have not noticed issue currently, but have only done short flights, in different locations. It was very weird when it happened, had not had any issues previously.
That's what I thought at first so I gained a little altitude to be in the clear and it continued to beep, sometimes for a couple minutes into the flight. No other anomalies flight-wise, just the beeping. I thought someone had mentioned that the sticks needed calibrating when it did that but it stopped doing it shortly thereafter.?‍♂️
Bandar200718
