Mavic Air 4kms out - Almost lost her
I've just crashed my Mavic Pro and The battery was at 6% and it dropped like a stone straight onto concrete right in front of me I'll never go under 15% battery again now that has happened to me. It's cost me 300 pound to fix everything
Ended up needing all arms replacing apart from one back one. Middle casing top casing all the camera wires brackets.
Lesson learned I tell you. View attachment 43441View attachment 43442View attachment 43443
The "Fuel tank" percentage left is only valid if you completely discharge the battery every 10-20 flights to Recalibrate the Smart Battery.
I never go below 30%
I was hoping it wasn't dashware, that software crashes on bootup for me. Don't know why. Tried previous versions too.. I have all the framework installed too.
Does it quit on startup? That happened once to me and unisntall and reinstall solved the issue.
If it breaks when loading the video or trying to generate the video, make sure that your video is 1080p or less and has audio, also make sure you installed the Visual C++ extensions.
That fixed it for me.
yeah it quits on startup. as far as i know i have all the C++ updates that i need, but i'm not sure if this is looking for anything specific. i know my framework was newer than wwhat it required. and it crashes on bootup, before I can even get into it.
Robby1983
