Here is my logfile: DJI Flight Log Viewer - PhantomHelp.com
I had control up until 12,5 seconds, after that it started drifting, and from the logfile it seems it had some little input on the left stick, but no matter how i tried it would just go away from me.
I then had to go down before it would hit the trees to the west of me.. also started to spin it to make it not go so fast into the ground.
A couple of days before this I had a quick popup, that went away in a few seconds, about calibrating the IMU, I then restarted and the error was gone, I checked the IMU and there was no need for calibration.. I then made 5-6 more flights before the one linked above.
My question:
I cant see any errors other then the tiny input on the left stick there at 12,5 seconds, could I have saved it? Did i just make it worse with the inputs I did to "save it" from the trees? From 23,8 second the left stick is centered and it keeps going"backwards and tho the right" (north on the map)
Sorry if I am rambling, but I just cant figure this one out..
(the drone is fine and I have made a few flights after this without problems, but i did calibrate Sticks, IMU and Compass)
My question:
