Mavic AIR camera disconnection
frulloa
Hello guys,
I have a MAVIC AIR. It went into the water on a river.
I fixed and now it is almost all ok.
The issue is that after 5-10 minutes the mavic air overheat. So, first I lost camera signal, then if I turn off the drone and turn on again the drone doesn't connect with the remote controller.
I have to wait like 5 minutes, in that time the drone cool down. Then I turn it on, and all good as new! but just for 5 minutes again.
What could be the solution for this? Should I need to change the mainboard?
Your fan might be shot. You can try changing the fan out, and hope thats the cause. If not, youre looking at a new board.
In the meantime, dont let that sucker run for 4 minutes if the fan isnt coming on. If you do, and the core board is not fried yet, it will soon be.
youyu
