Mavic Air Fly Away, but saved. Pls help
Slat
I need your help analyzing what happened, pls.
I almost lost my dron flying over water, when disconnected and flew in opposite direction of the Home Point. (2m 13.1s)
Hopefully, turning off and on my remote make it reconnect in the 46 longest seconds I ever had flying drones.
I fly almost every day and multiple times in this same location and sometimes lost video, other have strong interferences or disconected for a few seconds, but never saw my drone going in the wrong direction when returning home.
I took off with the Home Point correctly saved with 14 sats and 80% battery. I’m seeing a battery unbalanced in Sport mode, and will check take a closer look on this bat.
Thank you!
Reactions: Ds67888
It looks to me like it was retracing its flight path which, if I recall correctly, is standard behavior for the MA. When it looses connection with the RC, the MA will retrace its flight path for 60 seconds before returning home.
Reactions: dawgpilot
I think that is a feasable conclusion.
Reactions: Ds67888
That could be a perfect explanation.
I will keep looking and in the meantime I refreshed firmware an calibrated al sensors. Just in case.
Thank you
The MA has 3 different RTH settings. By default setting when RC connection is lost, it will retrace its path all the way to the home point. You can alter these settings in the Go4 app.
Reactions: Ds67888
canaryfersa
