Mavic Air missing video metadata
bazuchan
I had Spark and video files copied from its sdcard contained metadata (date, time and gps position), but files from Air doesn't contain this metadata. Am I missing something here?
Spark file:
Code:
% exiftool DJI_0078.MP4
ExifTool Version Number         : 10.80
File Name                       : DJI_0078.MP4
Directory                       : .
File Size                       : 123 MB
File Modification Date/Time     : 2018:03:08 16:34:54+03:00
File Access Date/Time           : 2018:06:18 19:44:32+03:00
File Inode Change Date/Time     : 2018:03:15 16:55:05+03:00
File Permissions                : rw-r--r--
File Type                       : MP4
File Type Extension             : mp4
MIME Type                       : video/mp4
Major Brand                     : MP4  Base Media v1 [IS0 14496-12:2003]
Minor Version                   : 0.2.0
Compatible Brands               : isom, iso2, avc1, mp41
Movie Data Size                 : 128583974
Movie Data Offset               : 48
Movie Header Version            : 0
Create Date                     : 2018:03:08 13:34:11
Modify Date                     : 2018:03:08 13:34:11
Time Scale                      : 1000
Duration                        : 0:00:42
Preferred Rate                  : 1
Preferred Volume                : 100.00%
Preview Time                    : 0 s
Preview Duration                : 0 s
Poster Time                     : 0 s
Selection Time                  : 0 s
Selection Duration              : 0 s
Current Time                    : 0 s
Next Track ID                   : 2
Track Header Version            : 0
Track Create Date               : 2018:03:08 13:34:11
Track Modify Date               : 2018:03:08 13:34:11
Track ID                        : 1
Track Duration                  : 0:00:42
Track Layer                     : 0
Track Volume                    : 0.00%
Matrix Structure                : 1 0 0 0 1 0 0 0 1
Image Width                     : 1920
Image Height                    : 1080
Media Header Version            : 0
Media Create Date               : 2018:03:08 13:34:11
Media Modify Date               : 2018:03:08 13:34:11
Media Time Scale                : 12800
Media Duration                  : 0:00:42
Media Language Code             : und
Handler Description             : VideoHandler
Graphics Mode                   : srcCopy
Op Color                        : 0 0 0
Compressor ID                   : avc1
Source Image Width              : 1920
Source Image Height             : 1080
X Resolution                    : 72
Y Resolution                    : 72
Bit Depth                       : 24
Video Frame Rate                : 29.97
GPS Coordinates                 : 37 deg 42' 57.40" N, 25 deg 29' 11.72" W, 5 m Above Sea Level
Handler Type                    : Metadata
Handler Vendor ID               : Apple
Encoder                         : Dji AVC Encoder
Avg Bitrate                     : 24.4 Mbps
GPS Altitude                    : 5 m
GPS Altitude Ref                : Above Sea Level
GPS Latitude                    : 37 deg 42' 57.40" N
GPS Longitude                   : 25 deg 29' 11.72" W
Image Size                      : 1920x1080
Megapixels                      : 2.1
Rotation                        : 0
GPS Position                    : 37 deg 42' 57.40" N, 25 deg 29' 11.72" W
Mavic Air file:
Code:
% exiftool DJI_0032.MP4
File Name                       : DJI_0032.MP4
Directory                       : .
File Size                       : 225 MB
File Modification Date/Time     : 2018:06:18 19:15:25+03:00
File Access Date/Time           : 2018:06:18 19:32:44+03:00
File Inode Change Date/Time     : 2018:06:18 19:15:25+03:00
File Type                       : MP4
Movie Data Size                 : 236279293
Create Date                     : 0000:00:00 00:00:00
Modify Date                     : 0000:00:00 00:00:00
Time Scale                      : 1000
Duration                        : 18.29 s
Preferred Rate                  : 1
Preview Time                    : 0 s
Poster Time                     : 0 s
Current Time                    : 0 s
Next Track ID                   : 2
Track Create Date               : 0000:00:00 00:00:00
Track Modify Date               : 0000:00:00 00:00:00
Track ID                        : 1
Track Duration                  : 18.29 s
Track Layer                     : 0
Image Width                     : 3840
Image Height                    : 2160
Media Create Date               : 0000:00:00 00:00:00
Media Modify Date               : 0000:00:00 00:00:00
Media Time Scale                : 30000
Media Duration                  : 18.28 s
Op Color                        : 0 0 0
Source Image Width              : 3840
Source Image Height             : 2160
X Resolution                    : 72
Y Resolution                    : 72
Bit Depth                       : 24
Encoder                         : Lavf56.15.102
Avg Bitrate                     : 103 Mbps
Image Size                      : 3840x2160
Megapixels                      : 8.3
Rotation                        : 0
Have you (if it’s there) turned on the subtitle option in the settings ?
i notice this same no gps info in exiftool and in srt file :( other DJI drones store position in srt file if you change to mp4 file format but no MA :(
DJI confirmed that the Air does not store any meta-data. I’m using ExifTool to add the create date and going to see if I can copy the GPS data from pictures taken around the same time.
djimini3
