Mavic Air Won't start anymore
I would still very well inspect both the props and the mounts, maybe even replace them preventively. Given how you have to force to fit the wrong props on it's very likely there is some damage that could cause something to break after a while.
Or lose a prop in flight. Which if often the result.
Reactions: Jcwww
Don't worry I'm a total newbie so it's highly likely I do stupid things :)
But yes, they turn freely. BTW, the replacement rotors that came with the fly more combo all looked pretty identical to me
Hi mate,
I needed to change a prop and did so.. But then I remembered reading the props have 'positions' and won't fly correctly f you the wrong prop.. By sheer luck I got the right one, but they are marked differently.
Reactions: Jcwww
Thanks I'll make sure to check on them on a regular basis, so far they seem to be fine, sitting tight
Gavthistle
