Went to charge the Mavic battery via the car charger, but for some reason the charger does not want to "connect" to the car power. Tried 4 different outlets in my 2013 Hyundai Santa Fe but none work. Other cig lighter devices I have work fine all over the car. However ... When I plug the Mavic car charger into a cig outlet on a car charger unit it fires up OK ???? My next test is to try another car to see if it works there. I suspect a "finicky" plug on the Mavic charger. I may end up changing the plug if that's the case. Anyone else experience any problems using the 12 volt car charger?
