Mavic Mini 2 Repeater
Gambiarrer
Brazil
Hello everyone!
I'd like to know if you guys ever tried something like a repeater for Mavic Mini / mini 2.
There is a hill in front of my house, and I'd like to place a fixed antenna with repeater on the top of that hill, so I can go further with my drone, controlling from my house.
I have solar pannels and other antenna there (no problem with interference) and flying from there (or having a repeater there) I can reach more places where i need to take care, without obstructions
Thanks in advance.
Reactions: fificap
WELCOME to the forum :)
Welcome!
Right off the bat, you are going to run into problems as the repeater (both it's receive and transmit function) will be operating on the same frequency as the controller. That means potential feedback loops and serious interference issues for drone (which will at times be "seeing" transmissions from both controller and repeater, and for the controller too, due to multi-path reception.
Keep in mind that DJI drones don't just use one frequency in each of the two bands they use (2.4 and 5.8 GHz). They will hop or change frequencies on those bands to avoid interference from other sources. So your control equipment must share that info with the repeater and drone.
What you are suggesting, is possible, of course, but it will take some serious engineering and equipment, enough that it'll make the hike up the hill, with your controller in hand, real appealing.
Reactions: fificap
Thanks guys!
Yes, hiking is still the best option lol
Thank you all and see you in the next threads! If I manage to build this repeater I will tell you!
Reactions: fificap
Hello everyone!
Thanks in advance.
May I ask what were you going to use for a repeater? Like a 2.4ghz router in repeater mode?
I would like to reply on the use
off something like a repeater.
I know the topic is older still the sollition?
I'am not so sure...!
Are you from Europe?
Does your controller only support the fcc standard transmitting the 25mw broadcasting....power.
This can be fixed easy, no fake GPS ********.
Only one minute and you are done and transmit full signal power.
If you want to know read the last alinia.
But if you really Wanne know read all.
Because i have been using one repeater for my cheap replica of the mini.
Called the JJR and this drone looks and works in the same way.
Except some things are different and those are the way that these drone's communicatie with the controller.
What i do know is that for the JJR it does work very good.
And you are not Breaking the Law....
If you would do like i am going to
tell you, know if you are withing Europe.
This is not allowed but possible.
But this drone and remote communicate separatly next to the phone and video.
Because that Will use the 5.8ghz for the video and the 2.4ghz for it's remote.
Even using the repeater its only repeating the 5.8ghz signal for the mobile while the remote signal is not even showing.
Second to that the DJI controller is connected with the USB-C to the phone
and its not using the phones hardware like
WiFi to transmit.
But only used to display the info on your screen.
You can test this by putting your phone into airplane mode.
Wich is even better, altough you Will see
that it should keep working.
On my iPhone IT did..!
So in theorie it could work.
Altough im unsure if you Will even
find the remote signal of DJI mini 2.
Next to this there is the question
about occu sync 2.
And how or if the repeater is able
to switch between these signals.
Just download the B3yond app
and unlock the full potential....!
Still there are people saying it's not
using the WiFi but some frequentie
within that range.
I think this is bullcrap because
it's either hidden or encrypted.
When it is not vissable it's more Likely
to communicate with a protocol link.
Just like any other Rc-transmitter that
switches or hop's within a pre-program range of the frequentie that is linked to the communication protocal.
But I cant test this out because i broke my repeater.
And well I have found my sollition.
So also i do not need it anymore.
Because the differance is insane to the fcc standard when i only made 1.6km in optimale conditions.
I'm now Just free to go like al off you outside Europe and that range is more then enough.
You only can fly so far before your battery is drained..
Be sure to reply....or share you mind...!
Always fly safe and responseble keep away from airports and be sure to not cause
Harm to others.
Keep the peace,share the love
and get the respect.
HAVE FUN!!!
Mamanov Ramazan
