Mavic Mini : Remote controller disconnected from aircraft(Code: 30029)
Aimar E
Estonia
Hello from Estonia. I did some flying with my Mavic Mini today, and got error. Then i did 3 flights more and then it was ok..no error no problems. I posted the link. And the Mode P or S that did drone itself.
Hi. I post my problem again here. To day was again dataloss error. It ocur when i was 1535m max distance. Its normal ?
is the explanation that airdata gives at the bottom not sufficient?
Explanation
Downlink data connection lost ( Data Loss ) means that the remote got partial or no flight data from the aircraft for more than 1 second, which means the data downlink had issues.
It is possible that during this time there is a sense of full control of the aircraft via the remote as well as clear video, however typically the video gets choppy and the remote controls may have some delay.
This is typically an indication that the aircraft was flying in a high interference area or that distance was a negative factor. In these conditions the aircraft is at higher risk of initiating the Return-To-Home function.
Please, make a test with another phone. (edit: looking your data the loss of signal dont seems to be your major problem).
a. Refresh the FW with the DJI assistant 2 including batteries.
b. Calibrate your controller.
c. Try another phone.
d. If its the same battery, try another new battery (the battery dips a little abnormal under high load).
good luck.
john_b3t
