mavic mini wlan connection
morkank
FI
Hi! change main board ( i live in FInland)..it's coming from USA..no wlan connection and red lights. Is this some country problem (wifi channels or what?).
Mavic mini using enhanced wifi, phone wifi cannot detect its signal. Mavic mini for USA market only support 5.8Ghz, can you try to select your transmitter channel to use 5.8Ghz and try to bind with the drone again?
Okay.. How I can change transmitter frequency.. Can it make Red lights?
/Jouko
Comnect your phone to remote control. Turn on ur rc and open dji fly app. Go to setting and choose transmitter. Over there you can choose 5.8Ghz
Reactions: morkank
What do you mean by clean tab? As like it has nothing? Can you attach screenshoot of that page? Have you connect ur rc controller to your phone and turn on the controller?
Yes.. Connected and turn on.. No transmission settings.. Info shows controller s/n..
Sorry, my mistake. I just try on my mini. Transmission setting will appear only after remote connected to drone. Have you try to pair your controller to the aircraft by following this procedure?
Hi what is the Europe main board right version.. Both wlan bands.. How can I see ebay listings..
-Jouko
Hi! I tested my old main board.. (waiting New).. Firmare upload stops 60% and drone booting all the time. Can I cancel / reset drone.. ( I can fly my old board.. Left camera connector is broken.. Still comes picture..
You can try to update your firmware using DJI Assistant 2 for Mavic from a computer. Make sure your battery at 100% when you fo it. What is wrong with your original mainboard?
No can do.. Pc and cable.. Mavic boot secuently.. Main board works until ask New firmare..then update 50%..and secuently boot.
/Jouko
Orginal mainboard gimbal? connector broken..
pejsvg
