- Joined
- May 19, 2017
- Messages
- 1
- Reactions
- 0
- Age
- 62
Hi, is there a Mavic navigator app for those used for cars?
In fact, I tried to pilot the Mavic by looking only at the App DJI Go 4 but the map or radar arrow always stays at point of the home point and only moves back and forth depending on Mavic's position. ..
You can not understand that where Mavic is at that moment ...
It can be understood from the dart only if the Mavic is forward or backward ...
You can also see on the remote control the distance from the home point and then see if the Mavic is approaching or moving away from the home point but you do not understand, as you would understand with the navigator, which way or zone is for example flying over the Mavic at that time ...
From the map of DJI GO 4 it is only the way homepoint is found (where there is also the dart ...) and you can also put the map in satellite or mixed mode. ..
If there was, as with the car app-navigators (eg TomTom), a dart that follows the Mavic, and tells you exactly where it is located, it would be much easier to drive it not to sight but to distance, looking only on the DJI Go 4 app on the smartphone ..
I think that DJI could make that APP as the Mavic has the built-in GPS (or DJI could even implement it in the DJI GO 4 APP ...)
Thanks so much
Thanks so much
