MAVIC photo coordinate elevation differs -18.4m then Google Earth and GPS equipment
Alvaro Lopes
Hi
Photos taken by Mavic in my fligths survey services differs from my GPS survey equipment for about -18.4m.
Identicaly in Google Earth that is +/- the diference!
I'm working in UTM 33s 15d (Angola).
How can I resolve this issue?
The Mavic GPS should be calibrated?
Rgds
Álvaro Lopes
Is it always in the same direction?
Have you compared this deviation with any other reference source other than Google Earth?
Hi
I only compared with my GPS survey equipment.
With coordinates no problem only with the elevation.
Yes
Thats the problem
At what altitude is the error being demonstrated? Consistently or when the Mavic is at high altitude or low altitude? The Mavic uses a few different methods to determine vertical positioning.
And you state that is the same error demonstrated in Google earth?
Yesterday I take photos at 0m, 2m and 86m.
I compare the photo altitude with the local altitude given by GE.
I started to do some survey fligths for my work as civil engineer.
For that I have to have some GPS control points in terrain.
Before using a mapper software the elevation taken by the fligth in those points have that difference.
I don't believe Google Earth has the same precision level all over the planet.
Did you check Mavick against some known height around you? (A building for example)
booboobambos
