Can anyone tell me if the MP1 controller and aircraft will still sync at distance? IE, can I fly out to see a mate at maximum visual range, land, and they change the battery? Then power it back up. Will it sync?
Cheers,
Dave
Cheers,
Dave
Yeah, thinking like photography of a mate who’s climbing a mountain. Especially if cold and poor battery life! Maybe even delivering something small.perhaps... IF you have LOS the whole time.... like in a flat barren desert or land on an elevated area where LOS is preserved.
I have successfully used the technique of landing, without powering off, on a spot above me and at distance in order to reset TO altitude so I could see over a mountain (ie fly higher absolutely than I could from original TO). Be careful... lose VLOS on landing and someone will have to retrieve the drone.Yeah, thinking like photography of a mate who’s climbing a mountain. Especially if cold and poor battery life! Maybe even delivering something small.
Interesting idea!There was a video ages back of a guy in Asia somewhere who kept landing on top of higher and higher buildings, disconnecting and then reconnecting at each step as a way to break the 120m ceiling limit.
So yeah it should be possible, but you might want to test it before risking it!
See post #4There was a video ages back of a guy in Asia somewhere who kept landing on top of higher and higher buildings, disconnecting and then reconnecting at each step as a way to break the 120m ceiling limit.
Also, did this reset ‘return to home”? I guess then you make the controller ‘home’?I have successfully used the technique of landing, without powering off, on a spot above me and at distance in order to reset TO altitude so I could see over a mountain (ie fly higher absolutely than I could from original TO). Be careful... lose VLOS on landing and someone will have to retrieve the drone.
.... that makes ”home” the location of the controller at that instant in timeAlso, did this reset ‘return to home”? I guess then you make the controller ‘home’?
Yep. That’s what I meant. If you didn’t, and something went wrong, it’d return home to some mountain ledge/roof etc.!.... that makes ”home” the location of the controller at that instant in time
