Mavic pro after crash can fly no telemetry or battery info on mobile phone nor the controller
Zotiss1989
So after water crash I cleaned both boards with wd40 electrical contact cleaner it flies and connects both with phone and rc but when it takes off it doesent register that it is in air it says take off failed but flies and it is controlled with rc and mobile phone it has video feed but no info whatsoever anyone had this problem?? Tried rc on second mavic pro and everything works fine so it is not rc when you calibrate everything calibrates and no errors whatsoever...
Does the phone display the time left until return to home is initiated?
It needs fixing that's for sure!
It doesn't save the home point cause it is not recognizing that it took off or that it is flying but it is stable in flight and holds position... flying smooth as for that, if it is the bottom board (with bottom sensors/cameras) it might not even be worth fixing??
Reactions: charliesRig
Where are you located? I have used core boards for sale.
strudladi
