Mavic pro battery 1 green light flashing on charge
andymagz
Hi all my mavic is plugged in after going down to 9% and when its charging only 1 green light (the upper most closest to connectors) is flashing.
Is this normal, will the battery charge up normally. I've never seen this before when charging as I've never charged the battery from this depleted.
Thanks all in advance
Have a look at the manual, at the Battery Protection LED Display section.
I assume you mean LED4 is blinking. Depending on whether it blinks twice or three times a second, it means the charging temperature is either too low or too high. Does this ring a bell?
Hi there, thanks for your reply , it is now blinking and charging as normal it was a worrying Time but disaster averted lol
so did you try charging it right after flying. if so, battery was to warm. it needs to cool down for a while before charging.
4Gabe
