Mavic Pro - Crashed Gimbal and Camera Repair
LeiScheidell
Coarsegold CA USA
I successfully replaced the video feed cable and the gimbal ribbon and was able to calibrate the gimbal. All is well is this area. With no apparent damage to the Front Sensors, DJI Go 4 is showing alert message that visual sensors are not working. I replaced the front sensors carefully reconnecting everything but I still get the error. I recalibrated the IMU and the gimbal. I don't really use the sensors to avoid obstacles anyhow, is there anything I should be aware of before I disable the sensors in the app?
Well if you think about it, not really. One thing is that sensors are not crucially important to flight, but make sure the bottom sensors are fine since that’s your visual positioning system and can cause drift when disabled.
Thank you. I will double check but I believe it only indicated front sensors then specific left and right front sensors.
CMDR DV TEARDROP
