Mavic Pro display gimbal tilt angle
pgh1949
Herefordshire, UK
Sorry if this is a dumb question but yesterday I tried looking for the gimbal tilt angle on the Mavic Pro controller or IOS app but couldn't find it. I wanted to pre-program a Litchi mission without using POI's and wanted to get the most appropriate gimbal angles by adjusting it manually and noting what angles I was using.
I've overcome it by taking a set of photos at different angles but it would be nice just to read off the angle while making adjustments.
Reactions: Chirp
If you set a waypoint to point at a POI, will Litchi show the angle?
Yes, if I create a Waypoint at a particular altitude and a POI then in the Waypoint properties it shows the angle. But what I wanted was to fly the drone and see what angle the gimbal was as I adjusted it with the control wheel, ideally in the DJI Go4 app.
...But what I wanted was to fly the drone and see what angle the gimbal was as I adjusted it with the control wheel, ideally in the DJI Go4 app.
I don't think Go 4 will give you the angle, just the visual approximation.
jimi79
