Mavic pro firmware update, then what should I do
Sandoel
Hello all,
After being doubting whether to do upgrade the firmware or not to do, finally I decided to upgrade it to the latest firmware. The process went smoothly using dji go4 apk.
Right after the upgrade I went to the dji go4 menu and tried to set again the return to home, and maximum altitude. I had a look also about new feature on it and I found I found panorama mode under camera. My question is: do ai miss something to do before I use it? Thank you for your kindly attentions, helps and supports.
Reactions: dazzer71
If your firmware is up to date, and your app is up to date, you should be ready to go!
Reactions: Sandoel
marcusjohn3684
