- Joined
- Jun 24, 2017
- Messages
- 185
- Reactions
- 108
- Age
- 52
I modded the latest (I think) DJI Go 4.3.12 with FCC, Boost, 32channel with default 2.4G/5.8G checked everything: sensor, compass values, aircraft heading etc. Then did something which never did before and on this and many other forums has been advised not to do. I kept DJI GO open and opened Litchi and flew and a mission to 5.8miles.
click on the Airdata link for all the info.
I was very pleasantly surprised, no dropouts, loss of signal, no problems. The reason for doing so was that I was not sure if the mods will work if i closed DJI and opened Litchi.
After flying to its limit almost, totally stock, I then switched to the modded DJI GO, closed litchi and came home in sport mode.
So that was a total of 11.6 miles stock.
So to come to the point, the modded DJI GO values like FCC, BOOST, 32 CHANNELS carry over to Litchi IF YOU KEEP DJI GO open.
I had 0 dropouts. maintained good signal, min was 42% at 5.8 miles, clear FPV with no lag.
With Litchi alone, I would start losing FPV around 4 miles and signal soon after.
So I'm excited. I'm going to experiment for longer ranges with battery mod.
