Mavic Pro gimbal issue, bumps and jumps when paning or turns
curso88
Hello
Someone have this problems with the Mavic gimbal?jumping or bumping when paning or quick turns. I observed that this problem is not present in the firmware 01.02.0900, but appears since 01.03.0000 and minimized but not fixed in the last 01.03.0200
Best regards
any one knows if there is a fix for this in HW or FW?
01.03.0000 both on the Mavic and the RC and the app is 4.0.5 on Android 7 nugat. I have not upgraded the FW intentionally as i read a ton of issues are to be found on 01.05.0000.
The gimbal was working fine on 01.03.0000 i think... but for sure was fine before 01.03.0000 all of this time, i never crushed or anything. Is this is FW related then? If I upgrade to 01.05.0000 though will have a ton of other issues.
Can i go back to 01.02.0000?
The gimbal was working fine on 01.03.0000 all of this time, i never crushed or anything. Is this is FW related then?
Hi
Upgrade your firmware. If is a firmware bug, is caused by the the gimbal buffer. I installed now the last version without any problem. If your problem persist after FW upgrade please, contact with DJI because the Gimbal Controller Board does not work propely
Reactions: Mr Spock
Hi
ok thank u for this!
I have the same problem.
Are the firmware updates recent? My Mavic has never prompted me to upgrade my firmware. I've had it for a month.
I had this problem in my Mavic and the firmware did not fix it. DJI replaced it for me.
tabarton94
