Hello,
has anybody experienced this problem already? I assembled a used Mavic Pro that was missing the cam/gimbal and the gimbal/front sensor control board myself with used parts. So far it works great, besides it does not turn the gimbal up completely to 30 deg. It's more like 20 to 25 deg. On the Go 4 App I see the dot going up but only to the penultimate marking and not completely up where it usually turns red. It completely goes downward 90 deg and the dot turns red there. During flights in sport mode it is also quite noticeable as the cam goes down on itself when it was horizontal before.
Strangely during a gimbal calibration it moves completely up and the dot turns red on the app when it stops on the uppermost level. But afterwards the movement is again limited upwards as before. Have done the calibration of the gimbal and controller left wheel multiple times also paired it to other controllers and calibrated the compass...can someone give me a hint which part could be the problem?
Thanks in advance
Thanks in advance
