Mavic Pro memory card
pomm001
Hi
Newbie questions, the micro SD card is 16 gb scan disk U3 ?
I have a spare Fuji 32GB Micro-SDHC Class 10 card in a phone, while same physical size question is can i replace the 16 with this
some of the video ( not all) i shot went straight to my phone, still pics didn't
unloading the card the stills are on the SD card , along with all of the videos
Thanks
I don't know the Pro specifically but the manual will tell you the maximum size of SD card you can use and I'm pretty sure it's more than 32gb, so in theory it will be fine. However it may not be up to spec in terms of its speed. Not all Class 10 cards are the same so you'll have to just try it and see.
I didn't understand the second part of your question at all? I'd transfer any files you want to keep, then format the card in the drone and start with a clean slate.
sscott062
