could be a fault with the GPS receiver or a IMU issueWhy out of the blue has my Mavic pro
Randomly started switching in and out of
Atti mode?
No I always fly outdoors..Your probably flying it indoors with poor gps reception and a dark environment so that the vps doesn't work
GPS doesn't "just go out"Prolly just gps going out
Atti mode?
Would love to but can not retrieve it.GPS doesn't "just go out"
You may have a hardware problem
If you want some insight into the situation, you'll have to post flight data.
You could post a link to the Airdata report for the flight.Would love to but can not retrieve it.
I have an iPad mini5 and iPhone XR.
Idk how to retrieve and send the data.
I use airdata
How do I do thatYou could post a link to the Airdata report for the flight.
Copy the link to your Airdata report (highlighted in this illustration) and paste it into a post here.How do I do that
I don’t have that on my device..Copy the link to your Airdata report (highlighted in this illustration) and paste it into a post here.
That's itWill this work.
Meta4,That's it
The flight was all above 100 ft except for the initial climb and final descent.
Your flight started with 17 satellites and normal GPS health of 5/5.
Normally for a flight like this the GPS numbers would be expected to stay similar for the duration of the flight.
But at 8:41.9 there waws a significant drop in numbers to 13 and a couple of seconds later it was 7-8 and GPS health dropped to 1/5 which means the drone is no longer in GPS mode and it's lost horizontal position holding.
After 12 seconds sat numbers started to rise again and after another 10 seconds the flight controller rated GPS health at 4/5.
GPS was dropped later in the flight three more times, the longest was for over a minute.
Actual numbers of satellites in your sky would have been stable and would not have dropped from 18-6 to 6 and back to 13 in less than a minute.
This suggests a physical problem with your drone, possibly a loose connection to the GPS receiver or something like that.
I'd keep an eye on it and if it's happening any more, have it looked at.
