I also did not, at first. Then it happened when launching on a windy day. It seems the increased wind caused my MP to overcompensate while hovering with the MPP props. Adjusted the gain settings and haven't had a problem since. This is a little long, but explains it well:
Did you set your gains as per his recommendation?Then to answer your question, it is a real thing. I would only get the gimbal shake error under conditions where my MP had to work harder to maintain stability.
I set it at 90 and the problem was gone without any noticeable change in performance or handling so I did not experiment further.Did you set your gains as per his recommendation?
