Max altitude in logs not accurate
Rockin G
So I was looking through my flight Logs and found a couple things. First I have two profiles on there for some reason...Not really concerned with that but still odd.
But the main reason for this post is that it says my max altitude is disturbingly high (for my taste since I purposefully try to fly within the regulations)...But when looking at the flight lists, nothing over 98' since I have my max height set very conservatively. Anything to do about that or just suck it up buttercup Screenshot_20170121-094136.png Screenshot_20170121-094156.png
I would say it is left-over data from a test flight or something, some people have mentioned even seeing a video of the DJI office on their SD card from test flights. I personally find it hard to believe they actually test flight every Mavic but maybe they spot check some of them and forget to wipe the data. You could probably contact DJI support and find out a way to clear it if it bothers you.
Reactions: Rockin G
Wesleydjimavic2pro
